94 accord hard starting!! Please help before i burn it!
Old Jan 10, 2012 | 01:00 PM
Sublime69's Avatar
Originally Posted by Roader
Maybe not. If the sensor just had out-of-spec high resistance (but not completely open) when hot then the computer would just think that the engine was cold, dumping in too much gas on a hot start. KΩ scale:
Interesting.. so where is this sensor located exactly? And any idea what they cost?
Thanks!
Old Jan 10, 2012 | 04:24 PM
That is why I asked about the wire color(s) going to the sensor to see which one is leaking.
Old Jan 10, 2012 | 08:47 PM
If you can smell the fuel, then check the vacuum hose on the fuel-pressure regulator. If there's any fuel in that hose, your FPR is bad.
Old Jan 10, 2012 | 10:26 PM
Roader's Avatar
Underneath the distributor, two wire connector, #19:
It's easy to check with a meter. If you don't have a meter, Harbor Freight sells one for $5:
Cody Is Cool
Nov 28, 2016 10:02 PM
ONeil1234
Aug 5, 2012 07:49 PM
Sublime69
Feb 1, 2012 07:54 AM
deserthonda
Jun 14, 2006 11:09 AM
MrRochie
Jun 24, 2005 08:28 PM
