94 Accord Ignition Switch
Old Aug 24, 2012 | 11:49 AM
Frank Ploof's Avatar
Default 94 Accord Ignition Switch
I have a 94 Honda Accord EX. I'm trying to replace ignition switch and in so doing have done something such that car will no longer start! Turing key provides no power to anything!.....all i did was remove 2 screws that hold ignition switch in place and then put 2 screws back in switch cover and now it won't even turn over....It does have factory installed anti-theft so I'm wondering if I have to reset it?
Old Aug 24, 2012 | 06:31 PM
I would start by checking the fuses.
Old Aug 24, 2012 | 08:06 PM
I checked the main 50a and it was ok......Note that there is NO power when I turn key to anything e.g. radio, fan, nor starter...
What other fuses?
Old Aug 24, 2012 | 08:30 PM
The #1 fuse (10 amp) in the under dash fuse box.
Also check that you got the electrical connector for the ignition switch plugged in securely.
Old Aug 24, 2012 | 11:10 PM
I do not have power on any pin on IS connector!
Will trace back tomorrow...
Old Aug 24, 2012 | 11:23 PM
Cthulhu's Avatar
If you figure out what the issue is please post your solution.
Do you have power to your dome light??
Old Aug 25, 2012 | 11:33 AM
If the white is not hot (12v to ground) at all times.....then yes trace it back.
Old Aug 25, 2012 | 11:41 AM
Also check that all the electrical connectors at the fuse box (front and back) are firmly in place. I recall someone on this forum having an ignition switch electrical problem that later turned out to be one of the connectors not firmly locked in place.
Old Aug 25, 2012 | 01:27 PM
Dome light works....Doug in under dash and found a mess: prior owner put in a remote start! So there are wires and splices and in-line fuses all over...I quit for awhile as it was overwhelming!
Old Aug 26, 2012 | 04:29 PM
This morning after chasing power back I found that in fact the 50a fuse had blown...I replaced fuse and reassembled all and now everything works....so I'm back to wear I started!! If I end up needing an electrical Ig Sw, I can now do in about 10 min.
Note on the sheared bolts: I used a chisel and hammer to loosen [one tap] and then fingered out and did reverse when reassembling...
PS... I also now know how to 'hot-wire'.....
tx all of you for help
frank
Matthew Kniss
Jun 30, 2014 06:00 PM
marks69cruiser
May 20, 2010 07:27 PM
Redcap
May 7, 2008 05:29 PM
Mikebike125
Jan 18, 2008 07:07 PM
illfaver
Aug 30, 2007 03:02 PM
