94 accord lx with vtec head gets weak at high rpms
Old Nov 22, 2007 | 07:56 AM
Jahsaccordcoupe's Avatar
Default 94 accord lx with vtec head gets weak at high rpms
When I go from a dead stop and from about 60 and nail the pedal to the floor it gets kinda weak once you hit about 5 grand seems like its not pulling hard anymore like its loosing power any advice on what may be te problem
Old Nov 22, 2007 | 08:51 AM
2POINTautO's Avatar
Default RE: 94 accord lx with vtec head gets weak at high rpms
Fuel volume low, valves out of adjustment, timing out of adjustment, air filter dirty. Need to see what the O2 sensor and MAP are doing. What is your MAP voltage at idle, need to know within .01 volts accuracy Carpet pushed up behind the gas pedal.
Last resort, dead head the fuel pump, clamp off the return hose after the fuel rail. Remove clamp right after quick run.
Old Dec 1, 2007 | 12:06 PM
HondatechAV6's Avatar
vtec head swap? is your oil level low? is vtec engaging?
cb7sk8rdude
Oct 9, 2011 06:40 PM
Snarfblast
Jun 3, 2009 09:11 AM
THE LEGEND
Apr 11, 2009 10:40 AM
pshepard8
Jun 19, 2008 08:25 AM
restrict187
May 20, 2007 08:23 AM
