Why the high pitch sound when rpms raise?
Old Oct 8, 2011 | 04:10 PM
cb7sk8rdude's Avatar
Default Why the high pitch sound when rpms raise?
Why is there a high pitch noise when the rpms raise? Is there a way to get rid of this?
Old Oct 8, 2011 | 09:02 PM
neophyte's Avatar
how close is your wiring run to the factory wiring? are the RCAs run with the power wire?
Old Oct 9, 2011 | 12:34 PM
The wires aren't that close the the factory wiring. The RCAs have their own way to the battery, they don't use the power wire.
Old Oct 9, 2011 | 06:40 PM
keep_hope_alive's Avatar
it is a common myth that running RCA's next to power wire will cause alt whine. it won't.
what causes alt whine is a ground loop. resistance between the HU and amp grounds cause this. this is a common problem with Pioneer head units due to an internal failure and open connection. also, head unit grounding is important, i ground head units to the floor to minimize resistance.
you say you checked your ground, but show us a pic. i find people don't know what to look for or what a good ground actually is.
jonnybingo
Aug 11, 2009 10:39 PM
petef23a
Aug 3, 2009 05:48 PM
bikener
Jun 6, 2008 03:06 PM
Jun 16, 2005 10:54 AM
