94 Accord random misfires and burning smell
Old May 16, 2012 | 12:52 PM
I have replaced clutch on 94 EX in place w/o discharging. It's not terribly difficult.
However, if the compressor has siezed (sounds likely), the system will need a complete overhaul to function long term. Debris from the failed compressor will contaminate the system. Best way is to replace compressor, condensor, evaporator, expansion valve, and receiver/drier. Flush all hoses/lines. Assemble, vacuum and charge to spec.
Old May 16, 2012 | 08:28 PM
pouncer11's Avatar
I just want it to work for another year or two, I am on a limited time frame and budget, I am building a large stereo in the car. Local guy said that I could just vacuum out the lines and it should clean it good enough.
Also a friend suggested I clean / replace the EGR that it and or bad gas could be the cause of the weird idle issues
Old May 16, 2012 | 08:43 PM
AC will work for a while, but how long is unknown. It depends how much debris left behind.
It is possible the expansion valve is blocked and no cooling is possible.
Shawnzie
Nov 14, 2013 08:25 AM
WhiteyM
Oct 21, 2011 06:28 PM
Pickrng
Jun 22, 2010 12:54 PM
MichaelT1960
Apr 11, 2008 03:03 PM
