94 Accord stalled, will crank but won't turn over. D4 is blinking. I've got the codes
Old Aug 13, 2012 | 09:25 PM
  #21
doctorbee's Avatar
since you repeatedly pulled codes 13,14 i think the ECM is toast. the FSM says that code 13 a problem with the BARO sensor in the ECM which senses air pressure.
code 14 points to a bad ECM.
Old Aug 13, 2012 | 10:06 PM
  #22
Crystal's Avatar
These are transmission error codes that are flashing.
13. Main shaft speed pulse generator open or shorted.
14. Linear (line pressure control) solenoid open or shorted.
Error code 13 for the BARO sensor is a CEL error code
But do you still think it could be the computer?
Old Aug 13, 2012 | 10:23 PM
  #23
doctorbee's Avatar
no, these codes are for a flashing D4
http://wikipediads.org/tcm-codes.pdf
the manual also mentions electrical shorts. that smell while you were driving could've been electronics frying which smells like burning plastic
Old Aug 28, 2012 | 10:49 AM
  #24
Crystal's Avatar
Just wanted to update... It was indeed the ECU. Bought a rebuilt computer from Advance Auto and had Honda install it. Car is back on the road.
Thanks guys
Old Aug 28, 2012 | 04:06 PM
  #25
AccorDats's Avatar
Glad you have solved the problem on your ride crystal.
I dont mean to hijack your thread but i have a question to all the accord gurus here, is there anyway that we could do to prevent this from happening? As the saying goes. " prevention is better than cure" or is it normal as to wear and tear is concered.
Thanks
Old Aug 28, 2012 | 06:53 PM
  #26
I think the only way to do preventative maintenance on an ECU is to open up the case and look for signs of bad components. Capacitors that are starting to bulge or leak would need replaced. Any resistor that looked burned, etc...
TexasHonda is a mod on here and had to replace his ECU. When he looked at the old broken ECU, he didn't notice any problems.
Old Aug 29, 2012 | 12:31 AM
  #27
AccorDats's Avatar
I guess i have to bring an extra ECU specially on long trips, thank you for the reply sir.
khwong91
Aug 31, 2015 04:03 PM
Jllace1397
Jun 30, 2013 02:25 PM
Quintin
Nov 10, 2011 05:33 PM
Ren920
Sep 26, 2011 06:27 PM
hammerman
Apr 11, 2011 08:21 AM
