94 Accord Vtak Solenoid Leaking
Old May 18, 2012 | 05:07 PM
pouncer11's Avatar
Default 94 Accord Vtak Solenoid Leaking
The Vtec Solenoid gasket is leaking and from what I have read its fairly common esp with high miles. I sprayed some carb cleaner around it to get the oil out of the area and sure enough its leaking out of the top pretty bad. The part is also hard to find I guess, but I managed to find one on ebay for 20 bucks. Before I buy it, I want to double check that it is indeed what I need.
OEM Honda Accord EX LX 4 Cyl F23 F22 Odyssey Acura CL VTEC Solenoid Gasket (P0A) | eBay
Old May 18, 2012 | 06:50 PM
Yes, that's the part. I installed one quite a few years back on my 94 EX and no problems since. Oring gets very hard and begins to leak.
Old May 18, 2012 | 10:45 PM
pouncer11's Avatar
Good deal. Now I just have to get the bolts loose on the egr.....
Old May 19, 2012 | 05:54 AM
A wobbly extension will allow access to bolts beneath egr rim.
Old May 19, 2012 | 09:46 AM
Well, there are two o-rings, that is the "lower" o-ring.....why not try the top o-ring, since you say that is where it is coming from?
pn 36172-P0A-005
EDIT: Online Honda dealers, you can get BOTH o-rings for ~$10 ?
grannie613
Apr 20, 2013 09:08 AM
Tchocky
Oct 5, 2012 12:36 AM
kennilope
Sep 14, 2010 09:54 AM
jtimc7
Oct 1, 2009 09:33 PM
kennyxu
Sep 26, 2009 04:50 PM
