Sponsored by:
Sponsored by:
94 hard starts, and low rpm misfire
Old 11-28-2017, 09:18 PM
greentjrtle05's Avatar
Default 94 hard starts, and low rpm misfire
Hello everyone, I have a 94 4cyl 5mt that's been experiencing hard starts a a misfire from idle to about 22-2300 rpm. So far i have tried a new coil, used ignitor, checked fuel pressure,cleaned the iac valve,cleaned the egr passages, plugs and and wires were replaced about 10k miles ago. At this point i don't know what else to check. Any other suggestions? Thanks in advance.
Old 11-30-2017, 08:13 PM
Is the check engine light turning on while driving? Have you checked for engine/transmission codes?
The RPM range is typical for an EGR issue. You cleaned the ports on top, but did you clean the top half of the plate? Check the vacuum hose going from the EGR valve to the vacuum controls on the driver's side of the engine bay.
Old 12-04-2017, 09:45 AM
Yes I checked for codes and there isn't any stored. I cleaned the plate also
porkchop
06-30-2019 02:44 PM
phantomgrey92
08-22-2013 07:42 PM
JACQUESFAUST
12-10-2012 06:29 PM
ex man
01-27-2012 09:46 AM
HondaAccordNewb
10-18-2007 06:51 AM
Quick Reply: 94 hard starts, and low rpm misfire
