94 Honda Accord manual transmission sloppy lose shifter>>help!
Old Oct 19, 2011 | 12:09 AM
Cheeva316's Avatar
Exclamation 94 Honda Accord manual transmission sloppy lose shifter>>help!
I just bought my first Accord, have had civics and integras mostly....
My issue is when either in the neutral position or while in gear the shifter has a lot of play side to side...I know on the civics there are plastic bushings or whatever to replace to fix this issue, but after hrs of looking and not finding any for my car I'm assuming there is a different set up?
I was also hoping to maybe get a "short throw shifter" for it and hoping that would also include with it the part that is causing the play I am getting?
I want to get this issue fixed before it causes damage to whatever else...please and thank you....
Old Oct 19, 2011 | 06:33 PM
Well if you are going with an aftermarket short shifter this might be a non issue. If not see this pic, you are looking at the shifter from ~the dash
Attached Thumbnails 94 Honda Accord manual transmission sloppy lose shifter>>help!-5th-gen-shifter-manual.jpg
watut
Jul 24, 2012 08:02 AM
fondahonda
Dec 14, 2011 06:21 PM
suprarx7nut
Mar 28, 2007 09:37 PM
heffus
Oct 18, 2006 09:23 PM
wforbush
Jun 28, 2005 02:00 AM
