94 LX Accord, cranks but won't start
Old Mar 26, 2012 | 02:18 PM
maddogtheman329's Avatar
Default 94 LX Accord, cranks but won't start
First tonight I couldn't get my car to start. It will crank but won't start. I've read a few forums and see what things I need to do to see what may be wrong (spark plugs, fuel pump). What I would like to do is add in another issue and some information and get some more expert opinions.
For the last 6 months whenever there has been rainy weather I've had a hard time getting my gears to engaged (at least that's what it feels like, also driving a manual). I would really be interested in what this problem is. And why when rainy?
Besides wanting to know the previous problem I bring this up because tonight when I had this crank but won't start problem it also seemed like I was really experiencing the second problem (also a rainy night).
Any opinions/help greatly appreciated, thanks.
As an update the next day the car started just as usual. The only difference I can tell is it's a sunny day. Another thing I should have mentioned is that recently when I leave the car in neutral and idle it'll periodically have a smooth rpm then drop slightly and the car will shake.
Old Mar 26, 2012 | 03:15 PM
96FiveSpeed's Avatar
I can't say for sure what the problem may be,But do a rainy day test.What that means,is when the car is running fine on a nice sunny day,open the hood and use a spray bottle with water and mist the engine in places while its running.
Do not soak it.
It might help you narrow down where the problem is.
I have seen cars run lousy in the rain because of old/bad plug wires,moisture in the distributor cap,modules,vacuum leaks,egr and etc.Some sensors like map or maf when wet can act up as well.
Hope you find whats wrong.Keep us posted.
frankferry
Jun 8, 2012 10:23 PM
Spectre
Jan 17, 2010 06:08 PM
jjrho
May 4, 2008 10:22 PM
LiquidR1
Sep 2, 2007 09:26 PM
thomks
Aug 15, 2006 06:43 PM
