95 Accord 02 sensor plug (Where is it?)
Old Feb 8, 2009 | 06:25 PM
okieflyr
Exclamation 95 Accord 02 sensor plug (Where is it?)
I've just replaced the engine in my daughter 95 Accord LX 2.2 auto, and need to hook up the o2 sensor. The sensor is in the pipe in front of the catalyst,and it's plug is on the support bracket, but I cannot (for the life of me) find the plug from the engine/ecu harness side. I used the original engine harness in the swap and disconnected it at one time during removal. But over time of the the switch, I've lost track of it.
Can someone please tell me where this plug harness originates from?
Does it exit from the engine harness? and where?
Or from the body somewhere? This is the silliest and most frustrating problem that should be a simple fix.
Thanks, Kevin
Old Feb 8, 2009 | 06:30 PM
It comes out of the harness that goes under the distributor in a plastic conduit. Same harness as the temp sensor, speed sensors, lockup solenoid, and shift control solenoid. O2 sensor is end of the harness from diagrams in my 94 Accord manual.
Download the 94-97 Accord manual from Online Manuals link for guidance. Page 23-17 in my manual.
Old Feb 8, 2009 | 07:12 PM
okieflyr
Default 95 Accord Sensor
Thanks TexasHonda,
All the sensors mentioned are plugged in, and with the age of the harness, everything already has a "set" to where it goes. I'll trace it from there thanks.
Kevin
"you have to be smarter than what your workin' on"
pondrun
Nov 8, 2021 09:40 AM
2002AccordSE
Mar 9, 2015 09:42 PM
wannakeepmy94Accord
Mar 14, 2012 08:06 PM
offroadTRD
Jul 3, 2009 06:38 AM
jon02accord
Mar 26, 2008 10:54 AM
