Need Help with problems
Old Feb 8, 2009 | 03:49 AM
IAMCANADIAN
Unhappy Need Help with problems
I have a 1991 Honda accord ExR automatic
Problems:
1) when i start it when its cold the rpm fluctuates between around 1100-2300 all by its self... but once it warm it seems to stop
2) i go for a drive up the road and when i come back the motor steams but its not oil it kind of smells like antifreeze but i don't see any leak from my rad.... where else could it leak from
3)Both my gas gauge and Temp Gauges don't work and i don't know why.... ?
if any one could help id be so thankful
Old Feb 8, 2009 | 08:08 AM
1) Idle fluctuation is usually caused by excess idle air; missing or open PCV or PCV hose, air boost valve stuck open, idle air control valve sticking, or other souce of air to the engine such as broken vaccum lines.
2) Coolant leak is most likely radiator, but a pressurized cooling sytem leak test performed on cold engine should find the leak. There are many possible locations for a coolant leak. Most auto parts stores have a loaner tool to perform this test.
3) Likely that sensors have failed or electrical connections to sensor are damaged or dis-connected. Check sensors for connection. There are diagnostic tests in the shop manuals.
Suggest download of 90-93 Accord manual from Online Manuals DIY FAQ links.
Old Feb 8, 2009 | 07:26 PM
IAMCANADIAN
i think the motor steam is coming from the hose that goes from the waterpump to the thermostat not sure what that peice is called but my friend is pretty sure judgeing by where the steam is coming from thats it. im wondering if that would cause the rpm to change as well ?
mamtsberg
Mar 17, 2010 09:15 PM
TommyTX
Sep 4, 2007 03:22 PM
95 Accord EXR
Oct 9, 2006 12:25 PM
KimberlyC
Apr 16, 2006 11:51 AM
junbei
Apr 13, 2006 01:37 PM
