95 accord 2.2 vtec ac problems
Old Jul 5, 2015 | 12:29 PM
turbofrank's Avatar
Default 95 accord 2.2 vtec ac problems
2 mos chasing ac blowing hot air. After driving 10mi ac start blowing hot air and at idle no water from evap drain plug. After unplugging 3 times removed evap funky and dirty i replaced evap and TXV and yes TXV is a little noisy. This was 1 of 2 problems . After fix ac worked good for couple days then started blowing hot air again. This time noticed ac clutch not turning and wide clutch gap. When removing compressor clutch plate fell off. belt was holding it on. Replaced compressor and dryer vacuumed system and recharged now blowing ice cold air
Attached Thumbnails 95 accord 2.2 vtec ac problems-096_zpsoxnx4suu.jpg   95 accord 2.2 vtec ac problems-089_zpseenpdxfh.jpg   95 accord 2.2 vtec ac problems-083_zps65crplhy.jpg
Old Jul 5, 2015 | 04:31 PM
Glad you got it fixed. Thanks for posting.
Did the 10mm bolt on the clutch fall out of the compressor?
What is TXV?
Old Jul 7, 2015 | 06:23 AM
turbofrank's Avatar
Yes bolt came out . txv= thermo expansion valve its on the other side of evap. I will try to find pic ..
Old Jul 7, 2015 | 08:12 PM
turbofrank's Avatar
txv
cd51994accord
Jan 30, 2014 12:56 PM
97hondaaccord
Jan 9, 2013 09:27 AM
Boogie
Jun 11, 2011 05:18 PM
KimberlyC
Apr 16, 2006 11:51 AM
