95 accord charging issues
Old Feb 1, 2025 | 08:32 PM
camerynh's Avatar
Default 95 accord charging issues
I've got a 95 2.2L ex accord and I've been having some issues with it for a while, I've replaced the alternator, had it tested and it's tested good, replaced several damaged wires, replaced the negative battery cable, when testing the power output straight from the alternator it shows as less than what it should be, any help would be appreciated
Old Feb 2, 2025 | 05:52 PM
What voltage measurememts are you getting?
Old Feb 3, 2025 | 08:36 AM
camerynh's Avatar
Around sub 10 V
Old Feb 3, 2025 | 03:43 PM
I'm not sure where you are putting your meter leads, so only having 10V to work from, the issue can be the alternator, the large + or -cables, mayby the ECU/alternator controls, and maybe a separated crank pulley/severly slipping belt.
Wiring is the quickest test. Put the red meter lead on the large + post of the alternator, then use the ground meter lead on the alternator housing, then the engine block, then negative cable from the battery where it bolts to the body, and then the - battery post. Let us know what voltage you get at each location with the engine running. Changing from 13 to <10 can locate a bad/poorly connected ground cable.
You can do a similar test where you keep the meter lead on the - battery post, then use the red meter lead on + battery post, then work your way to the alternator.
Old Feb 3, 2025 | 04:05 PM
camerynh's Avatar
Will test that out later tonight when I have time, will lyk when Im done
schlexzieberry
Sep 25, 2021 01:11 PM
Glassjaw
May 1, 2018 12:17 PM
john901
Jun 29, 2017 08:18 PM
bustum
Aug 31, 2013 08:06 PM
Devon7234
Mar 10, 2013 10:10 PM
