95 Accord EX 2.2 not starting
Old Jun 18, 2011 | 12:51 PM
fresnofrank's Avatar
Default 95 Accord EX 2.2 not starting
Hi Everyone, My 95 Accord will not start I've had a list of problems before this so let me list them:
1st prob- Car would not stay on so i was advised to replace my ignition (done)
2nd Prob- Car overheated due to cracked radiator (replaced)
3rd prob- Car kept turning off and would only start randomly, advised of a bad
bad fuel relay (Replaced it)
4th prob- Car continued to shut off while driving, towed back to mechanic and was told that my head gaskets needed to be replaced.....
Finally after feeling like I was being ripped off by this mechanic I had someone else take a look at it. He checked the timing and that was fine, he checked to see if there was any spark which there was and checked to see if gas was being pumped and that was ok too. His opinon was that the head gasket was not the problem and it has something to do with a mass airflow sensor/cam or crankshaft sensor but could not tell me for sure without reading the codes and couldn't read the codes because the car would not start.......
I did attempt to jump the ECU and when doing so my engine light stays solid.
any advise???? I'm lost..... The car cranks but will not start.
Old Jun 18, 2011 | 12:59 PM
How was the spark tested? Good blue spark at the plug.
Key to on/pos II the CEL comes on and goes off. I see you replaced the relay but just want to be sure. the pump should run while the light is on. Is there fuel at the rail?
LaGirl
Apr 24, 2012 05:29 PM
misterix
Feb 5, 2009 01:55 PM
cato2008
Aug 24, 2008 05:41 PM
MasterFlex
Aug 8, 2007 01:03 PM
thatboyjer
May 21, 2007 11:32 PM
