95 accord lx radio will not work
Old Jan 27, 2013 | 04:50 PM
bristang5's Avatar
Default 95 accord lx radio will not work
I have a 95 lx 4d accord. was in a slight front end accident now the radio will not work...fuses look good. I also noted that the cig lighter will not heat either...any ideas? thanks.
Old Jan 27, 2013 | 05:31 PM
Some of the common circuit items for the cigarette lighter and radio are the following:
  1. Fuse No. 11 (10A) located in the under-dash fuse box and Fuse No. 36 (15A) fuse located in the under-hood fuse box. -- Make sure you check both fuses in the separate locations.
  2. Ground location G401 - located behind left side of dash.
  3. Cigarette lighter relay - located behind front console.
Old Aug 19, 2024 | 12:27 PM
SweetT1212$'s Avatar
Default Cigarette lighter
How do I find the cigarette lighter fuse for a Honda Accord 1995 LX 4 cylinder
Old Aug 19, 2024 | 02:13 PM
Two fuses to check. Engine bay fuse box Fuse #36 15A. Driver's side dash fuse box Fuse #11 10A. The fuse box lids should have a diagram with the fuse numbers to help locate.
Dennis19
Nov 21, 2018 04:29 AM
Prospector
Sep 19, 2015 08:25 AM
ivrex
Nov 18, 2006 04:22 AM
netanderthal
Jan 20, 2006 06:33 PM
maximyshka
Sep 30, 2005 05:25 PM
