95 Accord No-Start
Old Dec 20, 2016 | 12:31 PM
Nathan Spencer's Avatar
Unhappy 95 Accord No-Start
Having a problem similar to this. I have a 95 2.2 vetec manuel. In the cold it usually doesnt start unless i have someone jump it and put starting fluid in it as well as pushing the gas pedal. I recently purchased this car from someone, he said he replaced the plugs and wires,and i recently replaced the thermostat. once it starts up, it runs really smooth. It also has a really small gas leak, but only a few drops every night.lastly, theres alot of vaccum lines going to nothing idk if that could be a reason, Any thing helps, Im tired of jumping it every day to get to work.Thanks.
Old Dec 20, 2016 | 07:46 PM
Without jumper cables, does anything happen when you try to start the vehicle? Or is the battery completely dead?
Where is the gas leaking?
Old Dec 20, 2016 | 10:52 PM
The battery isnt dead, i can crank it a few times before it dies and needs a jump, and i got it checked at autozone.Sometimes it starts without cables, but usually just cranks fast. And it looks like its leaking from a rubber gas line, but its been freezing out so i havnt had a good look.
Old Dec 21, 2016 | 07:29 PM
I made a new thread, because two different problems on a single thread is confusing.
A leaking fuel line is dangerous and is a potential fire hazard. You need to locate the leak and fix it.
I suspect that you are losing fuel pressure in the line and not generating enough fuel pressure to start the car initially. A quick test is to turn the key to the II position, but do not start the car. Turn off the key, and repeat a few times. Then try to start the car.
Tony1M
Nov 6, 2023 08:29 PM
rlmedina321
Nov 12, 2013 04:28 PM
Lunalobowolf
Oct 26, 2012 09:33 PM
gasface11
Jul 11, 2012 12:33 PM
brickballer
Apr 18, 2008 04:25 PM
