95 accord V6 Timing belt issue
Old Apr 12, 2010 | 07:53 PM
dazwyatt's Avatar
Unhappy 95 accord V6 Timing belt issue
is the 95 v6 an interferance engine? i have a 95 that the timing belt has worn through the timing cover and seems to be very loose. the engine started to run rough all of a sudden then died. Looking at the dist. rotor, it is no longer in time. What is the possibility of this destoying the valve trane? Do I put a new belt on and keep my fingers crossed?
Old Apr 12, 2010 | 08:11 PM
Its an interference engine.
If the belt only jumped 1 or maybe 2 teeth, then you may be ok. If the belt is not turning the camshafts, then the valves likely got damaged.
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
