95 honda accord ex idle problem
Old Oct 8, 2014 | 07:18 PM
tkj860's Avatar
Default 95 honda accord ex idle problem
when the car warm up it idles to low and the car vibrates what can that be
Old Oct 8, 2014 | 11:16 PM
I see your other post about knocking sounds from your engine.
Give us more information on both threads. Like what rpm is the engine running that is too low?
Have you done any work, had an accident, or had something like oil loss with this car right before the problem started?
What work have you done on this car?
Old Oct 9, 2014 | 12:20 AM
tkj860's Avatar
no accidents no leaks idles less the 1k i changed the spark plugs, spark plug wires, thermostat, changed the motor oil and tranny oil, alternator, added cold air intake the car has 170000 miles and when im at a stop light it idles low, when i start to accelerate it hesitates ; and the knocking when the car is in park and i rev the motor past 2000 rpms the knocking stops
Old Oct 9, 2014 | 05:38 AM
Turtlehead's Avatar
Start by cleaning the throttle plate and with the engine running spray throttle body cleaner into the IACV hole located inside the throttle body near the plate. Manually rev the engine while doing this or the engine may stall. See if that helps.
Old Oct 10, 2014 | 11:09 AM
There is a screen on the IAC that can get clogged and mess up your idle.
Once again, does the check engine light turn on while you are driving? Or is it always on? Have you checked for trouble codes? What is the rpm at low idle?
HatchJunki
Mar 9, 2013 08:23 AM
90pioneer
Apr 9, 2012 09:06 PM
RWilliams
Jul 24, 2011 09:16 PM
92Inspire
Aug 13, 2006 03:37 PM
fperezal
Jun 14, 2006 05:03 AM
