95 Wagon Ex Front End Clunking
Old Feb 1, 2011 | 02:56 PM
Boser1995's Avatar
Post 95 Wagon Ex Front End Clunking
New guy here. I have a 1995 Accord Wagon EX. I am having an issue with something in the front end. Whenever i decelerate i hear a loud ratching noise coming from the front end passenger side. If i pop it into nutureal it goes away. Also it makes the same noise when in reverse when aplying power. I have replaces both half shafts and front motor mount. Also it makes a noise when turning right at slow speeds but im sure its just a wheel bearing. It has around 340000 miles on it and runs great except this issue. Please help! Auto trans
Old Feb 1, 2011 | 04:43 PM
It could be a transmission problem since it goes away when in neutral.
Is your check engine light on, or does the D4 light start flashing when driving? I would still check for TCU and ECU codes, see how to get CEL codes in DIY section.
When was the last time you changed the transmission fluid?
Boser1995
Feb 1, 2011 04:55 PM
digitalayon
Sep 4, 2009 01:45 PM
jaybeezi
Aug 6, 2009 07:10 PM
locovaca
Aug 24, 2006 08:26 PM
corr04
Jul 25, 2006 11:32 PM
