96 accord ex clutch problems
Old Dec 23, 2011 | 03:45 PM
rydwg390's Avatar
Default 96 accord ex clutch problems
i have a 96 accord with a vtec engine and a manual transmission and i have a problem with the clutch. over the past few weeks 2nd gear would grind if i shifted to fast and now the clutch pedal goes to the floor and stays there. im stumped and would appreciate any advice i can get. thanks.
Old Dec 23, 2011 | 04:53 PM
Clutch is hydraulic and it's likely either master cylinder or slave cylinder has failed. You will need to inspect slave cylinder (pull boot and check for leakage) and inspect master cylinder for leakage.
Old Dec 23, 2011 | 05:05 PM
rydwg390's Avatar
I replaced the master cylinder today and slave cylinder is new. Could it be anything else? Thanks
Old Dec 23, 2011 | 06:49 PM
Yes, system must be bled correctly to remove air. Usually pump/release bleeding will eliminate air. Some pump fluild from slave to master to push air out the way it wants to go,..up.
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
KimberlyC
Apr 16, 2006 11:51 AM
