96 Accord hesitation in 4th
Old Jan 19, 2013 | 01:32 PM
dulamt's Avatar
Default 96 Accord hesitation in 4th
Hey guys,
Im experiencig a little bit of a hesitation in fourth gear, in the 2500 rpm range. It almost feels to me like the ecu is confused whether to shift into OD or not. It is the automatic 2.2 VTEC. Not really sure whether to be worried or not. Any suggestions?
I will say there is a slight fluid leak in the tranny, due to the cv axle being replaced in thebcar just before Ingot it, and the seal subsequently going bad in the process. But it is very slow.
Old Jan 19, 2013 | 01:40 PM
Watch rpm. If rpm is hunting about 100-150 rpm, then lockup may be engaging/disengaging.
Another possibility is EGR lean-induced miss due to partially blocked EGR ports. This can cause a hesitation feeling when acceleration is commanded.
Some AT codes can occur w/o D4 light flashing. I would check for obd1 codes stored in TCU. This may provide a clue.
Otherwise, not much to do except change the ATF w/ new Honda ATF and hope for the best.
SanDiegoAccord90
Jan 17, 2014 12:26 AM
letsclique
Jun 11, 2012 09:14 PM
SanDiegoAccord90
Feb 15, 2010 01:32 PM
HORSEPOWERJUNKIE2007
Jun 8, 2008 10:47 PM
SpanishN00b
Jul 28, 2007 09:24 PM
