96 Accord LX...P0141 code
Old Nov 19, 2010 | 04:31 PM
SirJohnIII's Avatar
Default 96 Accord LX...P0141 code
P0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit Malfunction
This is the code that came up when I got Autozone to scan my car today.
If I just replace the whole thing will it correct the problem or is it something else that needs to be done
Old Nov 19, 2010 | 04:58 PM
That code is for the second O2 sensor that is bolted into the catalytic converter. That sensor only monitors the catalytic converter for emissions, so it will not cause the car to run poorly.
If you unplug that sensor and test the resistance across pins 3 and 4 (the two pins opposite side of the clip that locks it to the connector), the resistance should be 10-40 ohms. Those two pins should have the same wire color. If the circuit is open, then replace the sensor.
Old Nov 22, 2010 | 09:26 AM
SirJohnIII's Avatar
Thanks..I will try to check the circuit today.
vaughnsimon
Apr 30, 2011 02:30 PM
alpac
Oct 13, 2009 07:22 AM
rahulvasudeva
Sep 14, 2009 10:38 AM
amanb
Dec 14, 2008 07:14 AM
22R
Dec 12, 2008 06:28 PM
