03 Accord Help Trouble Code P0141
Old Dec 12, 2008 | 02:35 PM
22R
Default 03 Accord Help Trouble Code P0141
Is this the O2 sensor in the Cat converter ? If so, How do you take the carpet up inside the car to unplug it ? Any advice is appreciated.
Great forum !! When I do a search for code PO141 i get no results ???
Thanks,
22R
Old Dec 12, 2008 | 04:05 PM
Default RE: 03 Accord Help Trouble Code P0141
Search function in the forum is not working. We can't contact the admin to fix it.
That code is for the secondary O2 sensor. It should be in the cat or right after. The first O2 sensor on your car is either on the exhaust manifold, or in the pipe right before your cat.
Old Dec 12, 2008 | 06:28 PM
hondadude's Avatar
I believe you will find the O2 sensor connector behind the rear subframe, in the engine compartment.
The code is calling out a fault in the heater circuit of the sensor.
Be sure there is power [12V]on the two black wires with the key on.
VPofOperations
Mar 27, 2014 01:02 PM
vaughnsimon
Apr 30, 2011 02:30 PM
SirJohnIII
Nov 22, 2010 09:26 AM
efster420
Feb 13, 2010 01:04 PM
amanb
Dec 14, 2008 07:14 AM
