96 accord starting problem
Old Sep 13, 2012 | 03:36 PM
orangemustang93's Avatar
Default 96 accord starting problem
hello I have a 96 accord v-tec that im having a starting problem... When i go to crank the car the fuel pump will not come on... I have changed the ign switch and the fuel pump relay... the car will turn over however the fuel pump will not come on.. The thing is though if i leave the car switched in the on position for abt 10 minutes or so the fuel pump will come on, the relay will click and it will start. Idk if all the accords this model do this but, when the fuel pump does come on a green box will light up around the D4 on the instrument cluster. also before the pump comes on and that light comes on I can move the gear shifter between the gears without pressing the brake... once the pump comes on i have to press the brake. so any info would be greatly appreicated
Old Sep 13, 2012 | 05:29 PM
doctorbee's Avatar
have you checked the MAIN relay? common problem on these accords.
Old Sep 14, 2012 | 03:28 PM
no i have not where is the main relay and exactly how would i test it?
Old Sep 14, 2012 | 03:40 PM
The main relay is the fuel pump relay. The main relay is on the passenger side of the steering column. It has 7 wires going to it. Is this the relay you replaced?
When you turn the key to the II position and do not try to start the car, does the check engine light turn on for about two seconds for a bulb check?
Old Sep 14, 2012 | 09:45 PM
Jorge07's Avatar
Yeah one does what's his is doing won't start did a whole tune up my check engine light comes on for. Few secs and then turns off
Old Sep 15, 2012 | 03:19 PM
the check engine light stays on so i couldnt tell u that lol. all the instrument lights come on though, and yes that is the relay that i replaced
Old Sep 15, 2012 | 03:26 PM
also are the anti theft or security systems on these cars?
Old Sep 15, 2012 | 09:07 PM
They don't come stock on the car, but you should look for an aftermarket security system. Look under the dash near the steering column for a control unit and wiring that looks out of place. The stock wiring harness is pretty organized.
Old Sep 16, 2012 | 03:42 PM
ok then thats not it either... so its not the fuel pump relay, ign switch, security system. any other ideas? because im at the point of full coverage and a deer
Old Sep 17, 2012 | 05:03 PM
I guess no one else has any suggestions?
Yamasaki
Nov 5, 2011 09:19 AM
quack31
Feb 5, 2007 05:07 AM
babylon888
Feb 16, 2006 02:08 PM
cyurgeles
Jan 21, 2006 10:36 AM
rev2ninetyper
Nov 14, 2005 04:06 PM
