96 accord starting probs
Old Jan 23, 2011 | 01:57 PM
ahren111's Avatar
Default 96 accord starting probs
im having starting problems with my accord. it cranks over fine & wants to start but it just dies. this happend the first time about 2 months ago, after cranking it over 7-8 times it finally started then was fine for a few months. then last night on my way home, first the clock went out, then all the gauges went & it died about 100 yards later & it wont start. anyone have an ideas??
Old Jan 26, 2011 | 09:54 PM
zstylelowrider's Avatar
From: Middle of nowhere Missouri. And in the center of my own universe.
What year is your car? With the way your describing you car dying, when it won't start check for a spark. I've seen quite a few times that the ignition control module goes out. Fairly cheap to fix if you know how to tear apart your dizzy. Your other issue with the lights sounds to me like it could be a charging system issue. Maybe bad alternator or battery. I would start there. Hope this helps.
Old Jan 26, 2011 | 11:38 PM
It sounds like your battery is dead. You should try jumper cables to start the car.
Did the battery light turn on when you were driving?
Old Jan 28, 2011 | 09:52 AM
ahren111's Avatar
wow a dead battery! im not a mechanic but im also not an moron. it was the ignition switch but thanks anyways
Old Jan 28, 2011 | 12:11 PM
I'm glad that you figured it out.
I try to make no assumptions on here.
That part sounded like either your alternator went out, or the battery/battery cables. I thought that maybe the two problems were unrelated. That is why I asked if the battery light came one before this happened.
spsweet
Jul 28, 2013 10:22 PM
carb_67
Oct 22, 2009 12:59 AM
deanog21
Nov 26, 2008 11:54 AM
stevieb
Jul 9, 2007 02:33 PM
Eric24
Aug 14, 2006 02:53 AM
