Sponsored by:
Sponsored by:
96 accord vibration when stoping
Old 05-29-2011, 07:11 PM
rcipra's Avatar
Default 96 accord vibration when stoping
I have a 96 accord that is vibrating when stooping the vibration can be seen in the steering wheel when applying the brakes. I have so far replaced both wheel beings inner and outer tie rods and brakes and rotors. If i just touch the brakes the car will come to a stop without the vibration but when presure is applied to the brakes it will vibrate a little smooth out and vibrate and the end before it stops. The vibration is noticeable toward the front of the car and as before on the steering wheel. I feel nothing in the break peddle its self. Was told it could be the controller arm? The car did set a year before i got it and started using it but have been driving it now for almost two years before this issue started. I is over due for a wheel alignment but was also told that it wouldnt be causign the vibrastion due to only feal it when stooping.
Thank you for your time and have a safe holiday
Old 05-30-2011, 08:59 AM
There are a number of bushings that could give you this feeling.
If you are due for an alignment, have them inspect everything (control arms, rad rod bushings, rack bushings, ect ) when doing this and have them balance and rotate the tires, at least then thry can be ruled out.
Old 05-30-2011, 11:59 AM
rcipra's Avatar
Way overdue for alignment so will start there. Ty for advice
wegipip
01-02-2017 11:37 AM
emrsar
10-02-2007 12:54 PM
jwelsch
02-12-2007 04:37 PM
Muffin
01-13-2007 11:01 PM
rottevnm
08-17-2006 09:59 PM
Quick Reply: 96 accord vibration when stoping
