93 accord vibration when braking
Old Feb 12, 2007 | 12:01 AM
jwelsch
Default 93 accord vibration when braking
I had taken my accord in because of a brake vibration so bought new rotors and had them installed with new pads also did the rear drums and now I still have that vibration when braking and only then . . could it be ball joints or bushings in the front suspension? car has 180,000 on it.
Old Feb 12, 2007 | 07:02 AM
juanortanez031278's Avatar
Default RE: 93 accord vibration when braking
do you have abs? this might be the causing your problem, whats the condition of your tires?
Old Feb 12, 2007 | 09:36 AM
jwelsch
Tires and balance are perfect . . also tried rotating front to back .. no vibration going down the road or at speed or turningso its not tires balance or alingment.
Old Feb 12, 2007 | 02:22 PM
Tony1M's Avatar
First, determine if it's front or rear brakes causing the vibration.
While going down the road, try using the emergency brake (rear brakes)alone. (Keep the button depressed as you do this.)
Doing this, do you still have vibration?
Old Feb 12, 2007 | 04:37 PM
ArcticHonda's Avatar
Take it back to the place that did the work and have them test drive it with you to see if they need to turn your rotors again.
Koss02
Mar 28, 2012 12:47 PM
89beater
Aug 8, 2011 08:19 PM
shergill
Dec 15, 2007 04:03 PM
ekcpapa
Jul 19, 2007 11:37 AM
inthedump
Jun 4, 2007 06:41 PM
