96 accord wont start
Old Jan 22, 2011 | 05:01 PM
mdeavelar's Avatar
Default 96 accord wont start
i have a 96 accord 2.2 5 speed. it was working fine and then i went to start it and got nothing. all the lights/stereo came on like normal and did not dim once key was turned. I also get no crank or noise once key is turned. I first tried replacing the ignition switch and got the same problem. the only way to get the car started to is to pop the clutch (which i know is harmful). with this being said should i attack the clutch switch or the starter next? how do i diagnose a clutch switch issue? thanks!
Old Jan 22, 2011 | 05:36 PM
Sounds like you have a starter problem or wiring problem. Do you hear one click when you go to start the car?
The quickest test for the wiring is to use a volt meter on the smaller wire (blk/wht I think?) going to the starter. Have an assistant turn the key to start and hold it there. That wire should have 12V to ground (use a valve cover bolt for ground).
Old Jan 23, 2011 | 07:05 AM
If no voltage at the starter, after doing the above, then go for the clutch switch-inhibiter. There are two on the pedal so be sure to test the correct one.
Tony1M
Nov 6, 2023 08:29 PM
jimmy3fingers
Oct 4, 2013 08:02 PM
gasface11
Jul 11, 2012 12:33 PM
MrGmo
Sep 28, 2007 01:40 AM
booter
May 11, 2005 02:26 AM
