96 Honda accord power loss
Old Sep 19, 2009 | 03:54 PM
juicejug
Default 96 Honda accord power loss
I have been driving this car around town and it has a brand new battery in it. I parked it after driving around for quite awhile and now it won't start. There is no power at all. I attempted to jump and there was full power. I then metered the battery and that has full charge. When I jumped it I connected the - to the motor lift bracket. When I tried to start it, it clicks but that is it. Any suggestions?
Old Sep 19, 2009 | 06:21 PM
Check all ends of both battery cables have clean connections and are properly tightened down. Use a 10mm socket (not boxed wrench) on the battery terminals to make sure they are tight. Check the two connections at the starter are clean and on tight.
Old Sep 19, 2009 | 06:31 PM
juicejug
Can this just happen all of a sudden with the cables? Is there possibly something in the starter that may be causing power shutoff? If I run a cable directly from the - on the battery to the lift bracket on the block all the power is resored but when I try to turn it over it just clicks.
Old Sep 19, 2009 | 07:30 PM
Just clarify one thing for me. There is no power inside of the car when everything is hooked up normally? When you ground the - battery post, you have power inside of the car?
Old Sep 20, 2009 | 07:10 AM
juicejug
It looks like there was a loose connection at the battery, but once that was located, the engine would still not turn over, it would just click once. I jumpered the clutch/starter switch and the same results. I just kept turning the key and then it finally started. Would this lead you to believe that the starter should be replaced?
Old Sep 20, 2009 | 11:16 AM
hondadude's Avatar
Starter contacts are cheap and easy to replace
eldonpet
Jul 30, 2012 07:44 PM
grim_reaper
Mar 4, 2011 08:37 AM
arnel9872
Oct 22, 2010 06:45 PM
tstan
May 23, 2007 04:06 AM
