97 Accord 2.7 Rats
Old Jun 9, 2023 | 03:03 PM
TexomaAccord's Avatar
Default 97 Accord 2.7 Rats
So this is the same accord that tried to kill me a few years ago, its been chillin. I finally got it back going, had to put a new fuel pump in it and some other stuff, it has been running great.
I went out to start it today, (It hasnt been started in about a week) and it turned over and then thudded (stopped). Almost like a seized engine would do.
I popped the hood and saw a big rat run out from the pulley side of the engine. UGH.
I got back in and turned the key, it turned a half a crank then stopped (thud).
Battery has juice, I'm wondering if there may be some dead rat I crushed somewhere that's stopping it. But where!?
Ideas?
Old Jun 9, 2023 | 04:39 PM
If you can't see an obstruction in the pulley/belt, you may have to remove the timing belt cover to see if they got the timing belt?
Old Jun 9, 2023 | 04:56 PM
I think there is a view port in the timing cover to check, I have a scope I can check when its not 100 degrees out. Storms tomorrow. Could a bad starter wire cause this? It spun over and just when it spun enough to start, it thudded and all the lights went off on the dash. I released the key and had power back. (Just remembered this power issue).
Old Jun 9, 2023 | 06:42 PM
Many times, rodents chew on the wires. Take a look also for chewed wires.
Honda even sell rodent tape treated with pepper to deter it.
Old Jun 9, 2023 | 08:46 PM
Loose wire on starter.. Fired right up. SOLVED
Frank PeƱa-Wright
Mar 4, 2014 03:51 PM
corey246
Nov 28, 2013 08:26 AM
jlisewski
Jun 24, 2013 04:04 PM
wade3673
Aug 26, 2012 12:27 PM
chibiko
Mar 25, 2007 06:36 PM
