97 Accord DX overheating.
Old Apr 29, 2011 | 12:21 PM
jcdrex's Avatar
Default 97 Accord DX overheating.
Hi, my 1997 Accord Dx 2.2L 4 cyl. 5 spd. m.t. 104000 miles. When driving on the highway the temp gauge rises to about 3/4 when using the AC. When I turn off the AC it goes down some, but when I turn on the heat full blast it returns to normal. This only happen when driving at highway speeds in warm weather. I noticed that around 30%+ of the radiator "fins" are missing. I had the coolant flushed last year but that did not resolve anything. I can hear the fans running when I turn off the car. My guess is the radiator needs to be replaced along with the thermostat. The coolant level is fine. Any help would be appreciated.
Old Apr 29, 2011 | 02:37 PM
I tend to agree w/ your diagnosis of damaged radiator needs replacement. I've found that cooling is adequate w/o any fans as long as car is moving at 20+ mph. AC will even work at decent speeds w/o fans. So overheating at speed is likely an indicator of damaged radiator.
To be sure I would first replace thermstat w/ OEM Honda thermostat. They are worth the extra bucks. If same performance, then a new radiator. I've found the inexpensive ebay radiators work fine. They were Chinese manufactured, but don't remember brand.
A used radiator may be an option also. Check car-part.com for a unit near your zip, plenty available for around $50.
Old May 1, 2011 | 07:47 PM
If 30% of the radiator fins are missing, I bet another 30% or 60% are corroded to the point that they'll come off if you sneeze nearby. That right there sounds like a good reason to get a new radiator.
Old May 2, 2011 | 07:32 AM
crispin's Avatar
I bought a new rad from Autozone for my 97
It was not expensive.
Joshporsche
Jun 14, 2006 10:07 PM
Rizzie
May 28, 2006 12:04 AM
copa708
Apr 24, 2006 08:36 PM
mennerja
Jan 6, 2006 10:03 PM
erikhaha
Nov 20, 2005 02:48 AM
