97 accord engine missing...
Old Jan 19, 2010 | 01:11 PM
drr5012's Avatar
Default 97 accord engine missing...
I have a 97 accord, auto…used very infrequently…the engine misses when under load roughly between 15mph-25mph, runs OK at higher speeds/rpm’s…what are the most likely causes besides the most obvious…air filter and fuel…plugs and plug wires….after that what? Thanks in advance for the help.
Old Jan 19, 2010 | 04:30 PM
Clogged EGR ports. Google T2T013.pdf. The 94/97 procedure is on the last two pages.
As for the tune-up. Replace distributor cap and rotor as well. I suggest using NGK or the dealership spark plug wires. Only use the NGK V-power copper plugs in your car.
Old Jan 19, 2010 | 06:14 PM
drr5012's Avatar
Thank you very much, PA...
Jskonz
Jan 28, 2015 01:29 PM
carl2782
Dec 4, 2010 05:54 PM
91guns
Jun 1, 2010 10:54 AM
AccordLXMaster
Jan 22, 2009 05:40 PM
bww
Aug 14, 2007 05:56 PM
