97 accord failed emissions, code P0725, read here that ignition coil is problem. Was
Old Jun 4, 2018 | 01:06 PM
Cindy McGrellis's Avatar
Default 97 accord failed emissions, code P0725, read here that ignition coil is problem. Was
Need help w P0725 code that failed my 97 accord for emissions. Saw post for replacing ignition coil, said definitely not a trans problem. Advice needed. Thank you
Old Jun 4, 2018 | 03:46 PM
Is this a 4 or 6 cylinder accord?
Old Jun 4, 2018 | 04:04 PM
P0725 = engine-speed input circuit malfunction
Is it a V-6 engine? I think that's the only one where I heard the coil mentioned as the problem. I don't have a shop manual for that generation (regardless of engine) so I don't know where that signal originates. But I will say that it could just as likely be faulty wiring back to the ECM so check that before throwing parts at it.
Luis Gutierrez
Jan 30, 2018 02:22 PM
faran
Apr 22, 2015 08:35 AM
ratram
Oct 16, 2011 12:28 PM
sugargenius
Jul 31, 2008 07:31 AM
camusmuse
Dec 9, 2006 08:29 AM
