97 Accord handful of problems, need help for d.i.y.
Old Jun 28, 2012 | 09:48 AM
astrocreep1369's Avatar
Default 97 Accord handful of problems, need help for d.i.y.
Hi all!
Car: 1997 Honda Accord, 2.2 vtec, 4 door, Auto trans, 243,000+
Well I guess I can make a list, but the importance of the ac issue is the highest. I live in southern Texas. The ac in my accord will blow cold momentarily, but then it changes to searing heat. Also, even without any ac on and the vents closed, very hot air seems to coming from the floorboard areas on both sides. As I am young and stupid, I thought I could take the heat and got heatstroke... Long story short, almost got it again and realized I need to address this. I was advised to check the heater control cable and make sure it is still connected, but cannot locate said part through my haynes(? Dunno which brand, no cover and missing some pages). Would love some help and ideas because I am a broke *** student also... Please help!
Old Jun 28, 2012 | 10:09 AM
The heater valve and cable is located near the engine compartment firewall. Check that the valve is opening and closing properly and that the cable is firmly attached.
You can download an online service manual from one of the links in the DIY sticky located above in this forum section. I believe the 1994 USDM service manual has most of the info. as the 5th generation Accords were all very similar. If you want, you can also download the different year supplements; but, they don't have too much additional practical info.
Old Jun 28, 2012 | 10:13 AM
Dr. Drivability's Avatar
sounds like you have a heater control valve issue or air mix control cable problem.
Old Jun 28, 2012 | 11:42 AM
The valve actuator cable may have come loose on the heater controls. If you look under dash on pax side you can find the actuator crank and cable end by turning the temp control dial on the AC/Heater control panel.
You may need to resecure the actuator cable and reanchor the cable sleeve.
Texas has had a brutal week of heat this week, especially for June which is usually just hot, not gasping, choking hot.
Old Jun 28, 2012 | 11:45 AM
Here's some additional info.
Attached Thumbnails 97 Accord handful of problems, need help for d.i.y.-ac-not-cold.jpg
Old Jun 28, 2012 | 02:55 PM
94ex915's Avatar
Almost A Senior Member
Ya Texas is very hot right now.... 103 where im at... No A/C and driving in a black car lol. Not very fun
Old Jun 29, 2012 | 09:30 AM
Default thank you!
Man, thank you guys so much for all the.advice. I will be gettin in there Saturday morn to see what's up... Thanks you all so much for the help... Let's hope it works...
PrettiBoiHonda
Mar 28, 2012 10:39 PM
mamtsberg
Mar 17, 2010 09:15 PM
petef23a
Aug 17, 2009 08:23 AM
ford
Jun 2, 2008 11:48 AM
KimberlyC
Apr 16, 2006 11:51 AM
