97 Accord LX transmission problems?
Old Jun 10, 2009 | 02:10 PM
ttorrey
Default 97 Accord LX transmission problems?
I've got a 97 Accord LX 4cyl. 150k miles. Check Engine light came on and we got it diagnosed. Mechanic said it was the transmission code and reset it. He said see if it comes on again, and if it does consider a tranny fluid flush. If that doesn't help, then it's probably the tranny itself.
Two days later the light has come back on, and we definitely can tell there is something wrong. Shifting gears (automatic) feels different, and today my wife said it wouldn't shift out of the 35mph.
My question: should I spend the money on a fluid flush in hopes that might be it? Or is it safe to say the tranny's gone?
Thanks
Thomas
Charlotte NC
Old Jun 10, 2009 | 02:49 PM
What specific code did it set? Codes are reported as P then four numbers.
You should be able to stop by an autozone and have them read the code(s) for you. Report all the codes and we will be able to give you more detailed instructions.
Old Jun 11, 2009 | 12:29 PM
ttorrey
Thanks. The code for the problem is "P07000 A/T System Malfunction".
I'm dropping it off at a Lube shop for a $43 drain-and-fill. I figure that can't hurt. And maybe that will fix it?
aandc2005
Nov 15, 2008 02:32 PM
a553487
Oct 27, 2007 02:35 AM
postred
Jul 11, 2007 12:35 PM
KimberlyC
Apr 16, 2006 11:51 AM
monroe
Oct 24, 2005 10:22 AM
