97 accord non-vtec to vtec HELP
Old Jan 8, 2013 | 08:37 AM
97hondaaccord's Avatar
It's a 4 banger. I'm at work at will let you know the number on the PCM. It seems right 37280 something something. I the doner motor was just sitting around at the shop I had it done at. I am no longer aloud to go there. But if I could this would be alot easier. Thank you all for helping.
Old Jan 8, 2013 | 11:48 AM
the number on the ecu is 37820-P0B-A70
881-114851
Old Jan 8, 2013 | 12:06 PM
since i dont have the uhm vtec wiring harness there is no pin in a8 so i just ran a wire from the green/yellow one on the soleniod and just put it where the a8 pin is. then test drove it didnt work. but then upon close look there is another plug that has 2 pins inside it im not sure what is it.
Old Jan 8, 2013 | 02:24 PM
Roader's Avatar
P0B ECU is from a '96 non-VTEC Accord. VTEC won't operate with that ECU. To get VTEC to work you'll need a P0H ECU. This TSB lists ECUs for automatic '96 - '97 Accords:
.pennybaker.com/ody/sb/SB%2001-012(dot)pdf
(add www to the address)
...but then upon close look there is another plug that has 2 pins inside it im not sure what is it.
Ignore that plug. It's for the VTEC pressure switch. The P0H ECU has no circuits to operate it. VTEC will work fine without it.
Old Jan 8, 2013 | 02:54 PM
Roader's Avatar
Found this digging through my engine swap links:
37820-P0H-L01 - 1996 2 & 4dr KA/KL OBD2 F22B1 VTEC w/5spd trans
37820-P0H-L02 - 1997 2 & 4dr KA/KL OBD2 F22B1 VTEC w/5spd trans
37820-P0H-315 - 1996 2 & 4dr KA/KL OBD2 F22B1 VTEC w/Automatic trans
37820-P0H-L54 - 1997 2 & 4dr KA/KL OBD2 F22B1 VTEC w/Automatic trans
37820-P0H-316 - 1996 5dr Wagon KA/KL OBD2 F22B1 VTEC w/Automatic trans (only comes in auto)
37820-P0H-A73 - 1997 5dr Wagon KA/KL OBD2 F22B1 VTEC w/Automatic trans
KA = 49 state emissions
KL = California emissions
Old Jan 8, 2013 | 09:54 PM
thank you so much. so i only use the green/yellow wire coming from the top? and i plug that into pin A8 on the ecu when i get the right one?
Old Jan 9, 2013 | 09:27 AM
  #17
Roader's Avatar
Exactly. Let us know how it works out.
99accordf23a5
May 6, 2014 12:51 AM
cd51994accord
Jan 30, 2014 12:56 PM
trukid21
May 4, 2012 02:44 PM
Boogie
Jun 11, 2011 05:18 PM
94coupeaccord
Feb 7, 2007 05:01 AM
