97 Accord overheating
Old Aug 15, 2012 | 09:11 AM
paulmezick's Avatar
Cold starts are fine, starts right up and sounds normal. Idle's at about 700-800 rpm after a cold start in the summer and then drops to about 600 rpm after it warms.
Old Aug 15, 2012 | 09:18 AM
doctorbee's Avatar
on a cold engine uncap the radiator, start it up, there should be no bubbles. if there are it's a sign that the head gasket is blown and coolant is being lost into the combustion chamber of the engine instead of going around it to keep the engine cool.
overheating usually causes blown head gaskets.
Old Aug 15, 2012 | 11:28 AM
Roader's Avatar
Originally Posted by paulmezick
Cold starts are fine...
Internal leakage symptoms can be quite subtle: one or two cylinders missing for just a few seconds after a cold (overnight) start.
I ask because you say there's no external leakage yet the reservoir is emptying. A gross internal leak should be detectable via Doctorbee's method. A small internal leak might require a leakdown test to detect e.g., pressurizing each cylinder at top-dead-center and looking for water pushing back through the radiator cap.
Old Aug 15, 2012 | 08:40 PM
Rad caps are cheap, replace or test if you haven't already.
From there, bleed and fill the system. Start the car and let it run (ac off) - of course check the temp gauge every now and then. Give everything a good look over once the car gets to op temp. You are trying to find a leak and there are plenty of places it could be coming from. Yes it could be a head gasket but I'm hoping for something else........when was the timing belt/water pump last done - weep hole on the wp?
Joshporsche
Jun 14, 2006 10:07 PM
Rizzie
May 28, 2006 12:04 AM
copa708
Apr 24, 2006 08:36 PM
mennerja
Jan 6, 2006 10:03 PM
erikhaha
Nov 20, 2005 02:48 AM
