97 Accord with rear main seal leak - what's the best way to top off the oil?
Old Sep 1, 2022 | 07:29 PM
ofmyownaccord's Avatar
Default 97 Accord with rear main seal leak - what's the best way to top off the oil?
My mechanic said my 97 Accord has a rear main seal oil leak, which he can't fix unless I want to pay him thousands to remove the transmission first. A few months ago I noticed the oil had stopped leaking. Maybe the oil had gotten dirty and thickened enough to stop leaking. Then I got an oil change (presumably with synthetic oil), and it started leaking again.
I want to top off the oil, but what would be best to use to stop the leaking? The 97 Accord normally takes 5W-30. Would a conventional oil be thicker than a synthetic oil? Or would it be better to try a 10W-30 oil?
Old Sep 1, 2022 | 08:08 PM
I would stick with 5w-30, because that oil weight is what provides the best wear protection in your engine. Just have a quart of oil in the trunk to ensure you can top off the level.
UhOh
Jul 6, 2014 09:05 PM
compiler
Oct 17, 2013 04:42 PM
jerrym
Apr 8, 2012 07:06 AM
jerrym
Jan 24, 2011 09:03 AM
jnc8651
Jul 30, 2007 12:10 AM
