97 accord runs with scanner only
Old Dec 16, 2014 | 11:52 AM
sharktooth's Avatar
Default 97 accord runs with scanner only
Just got through head replacement, timing belts & crank sensor
Couldn't get this to fire up until I hooked up a scanner from auto zone
Gave codes po141 & po135 oxygen sensor heater
As soon as I disconnect scanner car stalls and no spark or fuel pump working
Checked fuses, relay and all connections what gives? At a loss
Old Dec 16, 2014 | 12:24 PM
Check the G101 ground connection. See this thread.
https://www.hondaaccordforum.com/for...nnected-57403/
Old Dec 16, 2014 | 12:41 PM
sharktooth's Avatar
That's what I thought it was But I searched this whole engine top to bottom and can't find a ground anywhere, can I make one and where should it connect to?
Old Dec 16, 2014 | 12:48 PM
The thread has a photo of the location. That connection definitely necessary. It is on the intake manifold plenum.
Old Dec 16, 2014 | 01:02 PM
sharktooth's Avatar
Mine is definitely not there
This a non-vtec maybe I lost it in the rebuild
It is not by the thermostat housing either
Old Dec 16, 2014 | 01:14 PM
VTEC and non-VTEC have that same ground.
G101 is connected to:
VSS, radiator fan switches, PGM-FI main relay, DLC (OBD connector), and PCM/ECM, plus shielding between the PCM or ECM and these components (all have BRAIDED wires): CKP/TDC sensor, Countershaft speed sensor (A/T), CYP sensor, Mainshaft speed sensor (A/T), and Primary and secondary HO2S.
You car will have starting problems without it, as the PCM/ECM and main relay uses that. The PCM/ECM and the main relay affects fuel injection and fuel pump control.
Old Dec 16, 2014 | 01:39 PM
This attached photo is for the harness connector for the TDC/CKP sensors. This connector is part of the main engine harness. Follow along the main wire harness to look for the separate harness wiring that should have been connected to G101.
Old Dec 16, 2014 | 01:41 PM
sharktooth's Avatar
Found missing wire, it was folded behind another one Thanks for the Help
Are the codes something I can do something about? o2 sensor heater?
Old Dec 16, 2014 | 01:49 PM
Connect the ground G101, the code(s) may no longer be there afterward.
You may want to leave the negative battery cable off for a short while to reset the PCM/PCM or pull the back-up fuse.
forzaphil
May 30, 2016 11:10 PM
chris30721
Jan 6, 2011 08:06 AM
Accord Pete
Jan 31, 2010 02:50 PM
d_c_voss@yahoo.com
Jul 14, 2008 03:06 PM
crvone
Sep 28, 2007 10:55 AM
