97 accord/should I change my oil?
Old Apr 5, 2012 | 02:22 PM
argarcia86's Avatar
Default 97 accord/should I change my oil?
Someone told me, that since the oil in my 97 accord hasnt been changed in so long, that it wouldnt be a good idea to even change it.. He said it could mess up my tranny. Anyone else got anything to say about this?
Old Apr 5, 2012 | 02:34 PM
crispin's Avatar
I am going to try and decode your message...
Ah, you mean the transmission fluid?
Your transmission fluid has not been changed in a while and someone told you that changing it could be bad.
Am I getting this right?
Well that is not true, might have been true on some old neglected farm truck 40 years ago but not true today.
You should drain and fill your transmission using genuine Honda Fluid ASAP, repeating it 3 times total is best.
You really want to avoid neglecting your transmission, they have been known to fail suddenly. Wanna know how I know?
Old Apr 5, 2012 | 10:33 PM
argarcia86's Avatar
not only did this friend tell me, but a car repair shop said the same thing, almost the same words my friend said..
oh and yea I meant my trans fluid
Old Apr 6, 2012 | 01:23 AM
jerrym's Avatar
Almost A Senior Member
Cool
I have a 97 Accord 2.2 liter, AT and change my transmission fluid once a year. I think it would be a good idea to change your fluid, and if you do it yourself it only costs about 25 bucks for 3 quarts.
It is very easy to do actually. There is a drain bolt at the bottom side of the transmission facing the passenger side tire. A 3/8 ratchet fits in the square bolt hole drain plug.
I just did my Accord last week, and make sure you use 3 quarts of Honda fluid only. Also found out there is a new Honda AT fluid called DW-1, that is synthetic.
182K on my Accord with no shifting problems.
Good luck!
Old Apr 6, 2012 | 12:18 PM
6-Speed's Avatar
I did a drain/fill on my 97 using DW-1 a few months ago; no issues so far. The car now has over 151K miles and had seen 86K miles between AT drain/fills. I'll be doing D/F's more often now that I know how easy it is.
Old Apr 6, 2012 | 07:18 PM
jerrym's Avatar
Thumbs up
Yes pretty easy job and cheap insurance, so I think once a year is good.
Also the drain plug is magnetic, so when you remove it clean off all the particles real well before you reinstall.
PinkFloridaFlamingos
Aug 24, 2011 12:35 AM
chris h
Apr 3, 2011 10:01 AM
ziwang55
Jun 6, 2008 01:25 PM
deserthonda
May 21, 2006 05:24 AM
