97 Accord sluggish at startup
Old Jan 27, 2007 | 04:39 PM
DawgatAuburn
Default 97 Accord sluggish at startup
I have a 97 Accord with about 125,000 miles on it. It's a fourcylinderwith automatic transmission.The last couple of weeks when I have started it up and began moving, the car is extremely sluggish in the lower gears. Feels like is is not getting enough power, and shifting is slow.After 30 seconds or so, full power kicks in and everything is fine. This only happens after the car has been sitting for a while, like overnight or all day at work.
A buddy of mine thinks plugs and wires. Any other ideas?
Thanks in advance.
Old Jan 27, 2007 | 08:11 PM
drummer1279's Avatar
Default RE: 97 Accord sluggish at startup
plugs, wires, needing an oil change, clogged fuel system, trans fluid needs changed, etc...there are a few possibilities.
Old Jan 27, 2007 | 08:21 PM
hondadude's Avatar
have a look at the spark plugs, maybe a throttle plate clean.
Scrub out the ring of crud around the throttle plate
Old Feb 20, 2007 | 07:41 PM
maro's Avatar
Where is this located??? I'm a bit sluggish too.
Old Feb 20, 2007 | 07:48 PM
sir_nasty's Avatar
remove the intake hose from the engine, the part that it's connected to is called the throttle body, that's what the picture is of....
Old Feb 21, 2007 | 01:47 AM
maro's Avatar
thanks
lilytek
Nov 15, 2009 06:56 PM
sailaja_giri
May 24, 2008 05:27 AM
dsmulla
Mar 5, 2008 09:00 PM
tony11
Jun 5, 2007 03:31 PM
Jessab
Mar 24, 2007 06:51 PM
