97 Accord won't rev past 5500 rpm
Old Nov 16, 2012 | 09:38 PM
Cody_754's Avatar
Almost A Senior Member
Default 97 Accord won't rev past 5500 rpm
1997 Honda Accord SE with a JDM F23 VTEC swap. Running the P0H-L51 ecu. Engine seems to lose all power at about 4500 then acts like there's a rev limiter at 5500. No CELs! VTEC is not engaging I don't think. Any thoughts?
Old Nov 16, 2012 | 10:30 PM
Silver6gen's Avatar
is it a fuel cut limit? if your vtec isn't engaging then I would start at the solenoid then the electronics
Old Nov 16, 2012 | 11:24 PM
Cody_754's Avatar
When you hit about 5500 it sputters and acts like it just can't go anymore, I'm not sure what you mean by fuel cut.
Old Nov 16, 2012 | 11:57 PM
Silver6gen's Avatar
fuel cut is like a red line limit. like bammmMMbammmmbammmm... it revs hard till it hits then it cuts falls and revs again till it hits
or does it just "run out of steam"
Old Nov 17, 2012 | 08:23 AM
Cody_754's Avatar
It doesn't do that it's more like waaaaaaaaaaWAWAWAWAWA. It stays there as long as you hold the gas down. I guess you can say it runs out of steam.
I'll try and get a video!
Old Nov 17, 2012 | 03:11 PM
Silver6gen's Avatar
IMO I think you're dealing with 2 issues, sounds like you are running out of fuel and you vtec solenoid isn't functioning correctly. Could be electrical could be clogged.
Old Nov 17, 2012 | 07:57 PM
jroxz44's Avatar
5500 wouldn't that be Rev limiter? Or did u cut that out? Just wondering
Old Nov 17, 2012 | 11:55 PM
Silver6gen's Avatar
he says it looses power at 4k (probably due to no vtec) then it wont rev past 5.5k, standard rev cut is at 6.25k
Old Nov 18, 2012 | 01:11 AM
holmesnmanny's Avatar
Check for codes. Just because the check engine light isn't on, doesn't mean there aren't codes in there.
Old Nov 18, 2012 | 01:12 AM
Cody_754's Avatar
Exactly. I'm having the shop that swapped the engine for me troubleshoot all this. They are claiming that the solenoid and oil switch are both installed correctly, if that is true, is beyond my knowledge.
