97 Accord won't rev past 5500 rpm
Old Nov 22, 2012 | 12:47 AM
  #41
holmesnmanny's Avatar
Cody, if you want to use the h23a vtec injectors you need to take out the resistor assembly that your car is currently using, assuming the person who did your swap didn't already do it. You will need to do a search on how to wire it out.
Otherwise you can swap back in your old injectors and that might just fix your issue.
Let me know if you don't believe the advice I'm giving you and I wll just bow out of this thread altogether. It's not a big deal.
Old Nov 22, 2012 | 12:58 AM
  #42
Cody_754's Avatar
Almost A Senior Member
Honestly I don't even know which injectors I'm using. Roader claims that the F22 injectors will only fit so I must be using them. I also noticed you keep saying h23, remember, I have an F23 haha. I have no idea where the resistor assembly is on this engine nor what it is!
Old Nov 22, 2012 | 01:01 AM
  #43
Cody_754's Avatar
Someone suggested that I try cleaning my egr ports. I already did this on my old engine. Which if they used my F22 fuel rail then there would be no need for that.
Old Nov 22, 2012 | 01:06 AM
  #44
The egr ports go through the intake manifold not the fuel rail.
Edit: yeah i mean f23. lol
Old Nov 22, 2012 | 01:09 AM
  #45
Btw, egr only works between 1500 and 3000 so it wouldn't be affecting you at those rpms.
Old Nov 22, 2012 | 01:10 AM
  #46
Is this issue occurring with either the P0J or P0H ecu ?
Old Nov 22, 2012 | 01:37 AM
  #47
Cody_754's Avatar
I checked my engine oil (should've done that first thing), it was surprisingly low. I filled to the correct level hoping that was going to work but it's still doing the same thing. This issue is happening with both the P0J and P0H ecu.
Now, doesn't the ecu tell the solenoid when to activate? If the solenoid clicks when I apply the 12v to it, then that tells me that the ECU is NOT activating the solenoid right?
Old Nov 22, 2012 | 03:30 AM
  #48
Has your car always done this ? Did it pass smog like this ? Or did it start recently ? I can't imagine a swap shop handing your car over with this issue.
Old Nov 22, 2012 | 12:37 PM
  #49
Cody_754's Avatar
My car started doing this after I got this swap. I brought it back to them 4 times and they never figured it out so I gave up on them. The sad part is that they are a performance shop that builds engines and everything and they can't even figure this problem out when they are the ones that swapped the engine! And yes, it passed smog like this.
Old Nov 22, 2012 | 01:00 PM
  #50
Roader's Avatar
I tested out the solenoid and sure enough it clicked. I did it three times just to be sure, and it clicked every time.
Great! So the solenoid probably works.
Figure out how to keep one end of the wire in the solenoid-side connector. Route the wire through the passenger window so that you can close the hood without pinching the wire. Find a 12v source in the car. Just looking around, my radio pulls out easily so I'd probably tap into the radio constant 12v or ignition-on 12v. Attach another wire to that 12v source. Take the car on a highway without much traffic and - probably best to have a passenger to do this - touch the two wires together when the engine RPM is above 4000 RPM.
Tell us if the VTEC kicks in. It should be obvious.
