97 TRANNY
Old Jan 31, 2008 | 07:29 PM
cowboy from
Default 97 TRANNY
k got a 97 automatic w/the 2.2 when i put her in drive about 5 mins down the road the gear indicator starts flashing and it starts to slip alittle.changed the fluid but mno change.notice a lot of gunc on the drain plug bolt.didnt change the filter.so my question. most likely problem?
Old Feb 1, 2008 | 07:50 AM
Default RE: 97 TRANNY
A flashing gear indicator is like a check-engine light for the tranny.
Jumper the SCS connector as if you're going to read the error codes from the check-engine light. But your gear indicator lamp will flash the code instead (or along with) the CEL.
BTW, there's no tranny filter for you to change. There's a screen but you have to dismantle the tranny.
Good luck. It sounds like it could be bad news for your tranny.
bigtex
Feb 21, 2018 11:08 AM
tranwreck
Apr 30, 2009 09:27 AM
1993accordSE
Mar 18, 2005 03:01 PM
surfnsmps
Dec 2, 2004 05:48 AM
