98 Accord 4cyl LX , poor fuel economy, lack of power
Old Aug 27, 2006 | 06:19 PM
iqoair
Default 98 Accord 4cyl LX , poor fuel economy, lack of power
Hi guys, thought I'd throw this one out in the open and see what you guys think. My 98 Accord LX vtec (4cyl) gets pretty crappy mileage (500km/tank) on a 70 litre fuel tank. Also, seems a bit sluggish, lack of power. However, when I get down to the last 15-20 litres of gas in my tank the thing just hauls!! I'm leaning towards a bad fuel pressure regulator. It only has 110K on it. Fuel filter has never been changed, so I'll try that first.
Old Aug 27, 2006 | 09:26 PM
deserthonda's Avatar
Default RE: 98 Accord 4cyl LX , poor fuel economy, lack of power
ORIGINAL: iqoair
First of all I would like to welcome you to HAF...
mmmm.. i did a bit of calculation and here are the results
first off the tank capacity is ,,,17.1 gall which = 64.7 liters and not 70 liters as you stated
second 500 k divided by 64.7 liter ( tank capacity ) = 7.72 liter
there are 3.785 liters in a gallon .. so if you multiply 7.72liter X 3.785= 29.22 mpg
so in conclusion your car is getting 29.22 miles per gallon .........I'd say that 's not bad at all
assuming i did all my math correctly
as for being sluggish , now,, that's another issue.have you done any tune up?? 98 accords have the filter in the fuel tank part of the fuel pump.. it is suppose to be a lifetime filter.. and honestly i'd be surprised if that turns out to be the problem
Old Aug 27, 2006 | 09:33 PM
iqoair
Hey there. Thought the tank was a bit larger, so I guess my fuel economy isn't all that bad. The main problem I have with it is the power issue. Not much power from full to 1/4 tank, but anything less than that it really wakes up. It's had a full tune up, excluding wires. Plugs, cap & rotor, air filter. The reason I'm guessing at the fuel pressure regulator is because it seems to be a fuel delivery issue. I've also done a fuel injection service at a local garage. Doesn't make sense that less fuel in my tank gives my car more power, alot more.
Thanks for the reply, and the welcome
Old Aug 27, 2006 | 09:44 PM
YeuEmMaiMai's Avatar
150hp in lx and ex trims LX (for the I4) coupe is the lighest at 2997lbs and 150HP is not going to get you sports car performance. Fuel weighs in at approximately 6.5lbs/gal. so 12 gallson is about 78lbs = not much to be gained
Fuel delivery would be consistant unless it was a failing fuel pump...........
Old Aug 27, 2006 | 10:39 PM
iqoair
Not expecting sports car performance, just noting the huge difference in power when low on fuel, with or without an extra passenger. Has nothing to do with weight in this case. Perplexing...
WastingLight
Jun 12, 2015 11:07 AM
gdimattia
Nov 30, 2014 09:02 PM
Newby
Mar 4, 2011 10:56 AM
TBJ
Jan 24, 2011 12:55 PM
500$accord
Oct 25, 2010 09:21 AM
