98 Accord acceleration stumble
Hi
I have a 98 Accord 2.2 vtec, which seems to pull back on acceleration around 3800 - 4000 rpm, once I get to 4200 rpm its fine. I did the EGR clean up about six months ago when the symptoms were similar but at around 1800 rpm and has been good until this started.
Is it possible the EGR is fouled so soon, or would the higher rpm suggest I look elsewhere.
Thanks in advance for your help.
I think the EGR system closes under heavy throttle. This problem more likely caused by spark plugs, distributor rotor/cap, or wires unless Coil-over-Plug. Any Check Engine Light?
snowcat021
Sep 4, 2014 01:30 PM
