98 accord check engine light help
Old Jan 25, 2011 | 11:55 AM
  #21
I imagine most of the solenoid valves would come from a dealer.
try...
www dot hondaautomotiveparts dot com
www dot hondapartsnow dot com
but be aware of shipping & handling costs when you compare price against a local dealer.
Old Jan 26, 2011 | 07:46 AM
  #22
bozos_si's Avatar
Is there a diagram anywhere that I can look at to see where all the valves are at that i would need to check?
Old Jan 26, 2011 | 08:53 AM
  #23
EVAP canister is #6 in the picture. It's under the car, roughly below the left-rear seat.
Vent-shut valve is #8
Filter #9 might be plugged to cause the problem?
2-way valve is #14
solenoid that operates it is #7
both of those are inside a plastic housing #27
Vent-pressure sensor #36 measures pressure in canister & faulty measurement can lead to CEL.
Old Jan 26, 2011 | 08:55 AM
  #24
Up in the engine compartment...
#8 is the vent-control solenoid which is part of this system also.
Old Jan 27, 2011 | 11:40 AM
  #25
bozos_si's Avatar
Thanks for the pictures but I cant view them.
Old Jan 27, 2011 | 01:11 PM
  #26
click PARTS
put in your car's information
first picture (post #23) is category FUEL PIPE
picture in post #24 is category THROTTLE BODY
mickey4live
Jul 6, 2012 08:29 AM
horsebird
Dec 18, 2011 10:44 AM
hotrod01
Nov 11, 2005 01:28 AM
