98 Accord - Cutting Out
Old Nov 30, 2013 | 04:53 PM
t-roy's Avatar
Default 98 Accord - Cutting Out
I have a 98 Accord and it has started cutting out. It had a P0401 code changed EGR valve and cleaned ports that was resolved however it is still cutiing out. When it gets warmed up it will cut out between 2000 & 3500 RPM. It drops down to 500 or so RPM and then picks right back up. It drops off again and then up. When I pump the pedal and get it around 4000 it will hold there fine. Wiggling the key switch has no effect it seems fine. Already seen two mechanics and need to solve the problem with no more bleeding. Please Help.
Old Dec 1, 2013 | 06:16 AM
Do you know what has been tested?
I could give some things to test/check but that is about it.
4 or 6 cyl?
Tune up items (cap, rotor, inspect wires, plugs) are up to date. I'd be interested in the signals from the O2 sensor(s) - they can get lazy and cause issues without setting a code.
Thumper
Oct 2, 2011 04:41 PM
Tolvar
Nov 30, 2009 07:17 AM
HondaGuy256
Mar 8, 2009 10:27 AM
moonlight03
Mar 18, 2008 01:36 PM
wisey
Jan 24, 2008 07:02 PM
