98 accord engine swap or fix tranny?
Old Aug 16, 2009 | 04:01 AM
92accord808's Avatar
Default 98 accord engine swap or fix tranny?
hey guys i have a 98 accord lx auto trans.
mechanic told me that i have a bad tranny.
problem: when the car is running on idle, the RPM goes up and down but when the fan turns on it stops. also everytime im driving it just right after a complete stop, the car jerks. my cousin(also mechanic) told me it might be clutch.
shop qouted me $2,500 for the rebuild on trans.
i found a 99 accord engine and trans for $1,200 with 120k mileage.
guys help me, what should i do?
Old Aug 16, 2009 | 08:34 AM
deserthonda's Avatar
ask the shop how much they will charge you to install your transmission ,,,,,,,it should be around 6-7 hrs labor ,,$ 600-700 ? then you got rear main seal which i would replace $ 20-25 ,, tranny fluid ATF-Z1 $ 35-40 ...you can do the math
...Just so you know, if the shop installs your tranny they will not give you any warranty on YOUR tranny ,,if anything goes wrong a few miles later and it is internal tranny issue you got to pay labor all over again ,,
so it might be cheaper for you to get the used assembly ( engine-tranny) for $ 1200 ,, and have them install your tranny and still have an engine left over
As for the rpm flaring, could be low on coolant or a vacc leak or base idle just set up too high..
your cousin telling you that car jerks coming to stop that it could be a clutch ?? does he know that it is an Auto tranny ??
Old Aug 16, 2009 | 07:37 PM
i forgot to mentioned that the check engine light is on. ill go to a shop and have them read the code and ill get back to you guys.
for the installation i think i can do it my self.
thanks for the input!
schuster
Dec 16, 2011 10:30 AM
superballz00
Mar 23, 2009 10:56 AM
BertMan
Mar 2, 2008 09:07 PM
nixalot
Jun 10, 2006 05:28 AM
